- 13 Jan 2004
- South East
I'm all confused by this. I think I might just get the Keno ones for about £85.
Ebay is blocked for me at work (grrr) so can't see that item - although tbh I'm trying to figure out what does what myself. From my limited researching, you have to spend a reasonable amount to get tubes which allow for changing aperture as per normal on the camera.
I'm tempted to buy something like a 135mm M42 lens to get a bit of extra length, and whack some tubes on that. Could be fun!![]()
What is the difference between autofocus and autofocus confirm?
I've just bought a helios 135 f2.8 manual lens and plan to do just this just got decide what tubes to get, this lens won't autoconfirm tho so some cheapy £5 tubes will do.
AF confirm only confirms focus by lighting up the AF point and beeping. AF retains all functionality of the lens as if it was mounted directly to the camera.
I think this would be the best choice, the Kenko tubes are known to be good and you shouldn't have any problems with them coming apart and having your 24-70mm take a trip to the floor like I had with my Jessops tubes.
Oh I see, so I have to focus manually but it does still confirm when in focus?
I prefer to use MF with macro anyway![]()
