They run off the mains (1 plug each) both 250w as stated. How much is it going to cost per hour to keep these on?
Many Thanks,
Jake
Yet they dont draw 250W continuously.
Because light output in Watts and what they draw aren't directly related.Why wont a light continously draw it's rated power?
40w of energy is emitted from the light bulb, but it's not the same as watts in electricity, as 9w is only drawn at the wall.
You have a magic light bulb that creates energy.
Or, assuming you didn't go to Hogwarts, you're mistaken. If you have an energy saving lightbulb then it's likely that it's a 9W bulb (it draws and emits 9W) which has a similar brightness to a 40W incandescent light bulb.
Watt is a unit for 1 joule of energy per second.It's not, it uses a filament bulb.
Watts in heat, electricity and light output aren't the same thing.
For example, I have a lamp that states "40w Max" with a 9w power draw.
