Go for a used Auto Seamaster for about £8-900
Is that how much they go for second hand ?? If I could get £900 for my auto Seamaster then I would part with it to upgrade to something else.
something like a Breitling Colt Auto should be in your price range used
Or stretch the budget to about £1300 and you can pick up a very nice used Planet Ocean
there's a mid size auto sea master for sale at the moment on tz for £595 seems cheap but the mids are not as popularIs that how much they go for second hand ?? If I could get £900 for my auto Seamaster then I would part with it to upgrade to something else.
Spamalot, if you were after a PO would you want the 42 or 45mm and strap or bracelet ?
It would have to be both a strap and the larger of the two. I'm a big bloke, 6"3" and 15st so bigger is better.
nice choice
I asked seeing as I know as a potential 45mm on bracelet
have to say the 45mm on orange strap is amazing
There should be a list of ADs on Omegas website
Whats considered to be an acceptable discount on these?
Well you can get 15% back using Quidco from goldsmiths. You can also get 0% interest over three years so thats got to be the same as 20%+ discount.
20% for cash is as good as you will gte on a PO so 15% + interest free is pretty good
normally you only get interest free if paying full list
