Hey guys, been a while since posting, built the system in my signature around a year ago now, I'll review the hardware that's inside in a minute just to double check but first I'll outline my situation.
Just arrived at University in Nottingham, woop etc. plugged my PC straight in and all the lights in my room went off, bugger, so straight away figured too much power was being drawn, so I unplugged everything else in the room and flicked the room fuse back ( there is a switch box just above the door which was easy enough
), turned the PC back on and all worked fine, however, I basically can't use anything else in my room now whilst my PC is on which is somewhat inconvenient so I'm thinking of removing the current power supply and putting in a smaller one.
Hardware
1 x 1000Watt power supply
1 x Gigabyte X58 -UD4P motherboard
2 x Nvidia GTX280 in SLI config
1 x Core i7 CPU overclocked to 3.8 GHz 1.43 Vcore
1 x 7200 RPM harddrive
1 watercooling loop (CPU only) using a Swiftech Laing D5 vario pump
5 x 120mm fans, including the three on the radiator for the w/c loop
1 x Bluray drive
Whacked this in the power supply calculator here http://extreme.outervision.com/PSUEngine
and it said I should only need around 650 Watts? :/ Anyway, just wondering,
1. If a 800W power supply would be sufficient
2. If I do downgrade to an 800Watt power supply, would it actually change how much power the computer is drawing from the mains at any one time?
For the past couple of weeks I've been stuck with using my lappie, a 2 year old Dell XPS which is hardly crap but I'm bummed to say the least my PC is acting as a paper weight
Anyway guys, any help with this would be hugely appreciated!
Thanks
Hardware
1 x Bluray drive
Thanks
