Works perfectly here. Crysis on the other hand, crashes on first launch, and then when you change options in the menus. It will work if you dont touch anything
When I ran the benchmark yesterday with my hd 5870 several times at enthusiast, direct x10, 1920x1080. aa x2 on ambush fps were about 31fps, today I have ran it several times and it is averaging 39.35 fps. I have not changed the driversin the last couple of days and cant work out why this has happened. Other benchmarks are around the same score its just crysis that has jumped.
It seems that the benchmark is only recognising aax0 and aax2 anything higher than aax2 is seen as aax2. Has happened when reinstalled the program, in ati tools it is set to application controlled for aa etc. When run the tool aax16 still getting fps of 39 same as when aax2. I have tried reinstalling a more recent version of the benchmark and it still the same.
