To be fair even HD rips of Bluray movies are typically lower bitrate than the actual Bluray. If a 1080p BDRip is 10-13GB and a straight Bluray disk dump is 25-40GB+ then it's fairly obvious it's a reencode. That's not to say that it's probably 95% of the quality, but just saying...
If you are unwilling or unable to see the difference between an exact replica and paying homage to or taking inspiration from something then it's pointless even trying to debate it with you, especially as you seem keen to try and twist my words to fit your arguments.
If you could build an exact replica of a Ferrari that looks & performs identically then more power to you. I suspect Ferrari would take issue with you copying their design though, and since you didn't come up with the design in the first place (and presumably couldn't - otherwise why would you be copying it at all) then isn't the designer due their portion of payment for it?
That being said it's purely academic because you couldn't build an exact replica of a Ferrari, whereas if a Ferrari was digital you could make an exact copy of it without any technical ability whatsoever.
At the end of the day it's all paper-thin justifications for ripping off someone elses content. You couldn't create it, otherwise you would, instead you just copy it and pay the author nothing for their work. If you're going to do that then just do it - but don't try and dress it up like the author isn't losing anything when if the option to pirate it wasn't available you would have to buy it if you wanted to enjoy it.
You obviously don't understand the distinction between making a replica and ripping off.
Ferarri couldn't do anything if some one made their own replica of a Ferrari.
If you believe they could, on what grounds?
