Electric Drums Recommendations :)
Yamaha DTXPLORER
It is apparently, quite a good set for a beginner - and just under your budget ;)
Also - Gears4Music uses QuidCo, so you can get a MASSIVE 4% off ;)
Ive got this one. picked it up a month or 2 ago. 400 2nd hand on the bay. i quite like it, altho i can see i will be limited when i get better, but for a beginner it seems perfect. the metronome is very handy.
Forgot to remind you: don't forget to get a bass drum patch for the kick drum otherwise the fibre/felt on the majority of beaters will quickly eat through the rubber on the sensor.
Gaffa tape is the way forward thats what im currently using :D
