Unchartered Ground New Build
28 Oct 2009
Well first of all, i'd like to say Hi to everyone.I only became aware of this forum recentl via a friend, and having done so i am hoping that overclockers will do me a "new build"(cannot do it myself unchartered ground, always bought pre built ones)
Anyay i have put a package together and was after some help with either advice or tweaks.Below is my list:-
Coolermaster Cosmos PURE Black Silent Full Tower Case £179.99
OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Asus Rampage II Extreme Intel X58 Motherboard / Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz DDR3 Bundle £689.99
Sapphire ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card [21161-00-50R] £298.99
or
Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card [21162-00-50R] £221.98
Two
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) [HD103SJ]
£61.98 x 2
LG BH08LS20 8x Blu-Ray-RW/DVD±RW Dual Layer SATA Drive - Black (Retail) [LGBH08LS20.AUAR] £149.99
Sony Optiarc DRU-870S 24x DVD±RW SATA Dual Layer ReWriter (Black) - Retail [] £23.99
Corsair TX 850W ATX SLI Compliant Power Supply (CMPSU-850TXUK) [CMPSU-850TXUK] £108.99
or
Corsair HX 850W ATX Modular SLI Compliant Power Supply (CMPSU-850HXUK) [CMPSU-850HXUK] £135.99
Windows 64bit Ultimate ? do i need ultimate ?
Raid 0 card ? which one?
extra 5 usb card which one?
Do i need a sound card or is the one onbuilt to the motherboard good enough?
The only item i won't change is the coolmaster Tower which i think is really smart,but i am open to suggestions on any of the above.Any advice would be much appreciated.
Thanks
What are you going to use it for? What is your budget for everything? Do you need a monitor? You dont need Windows 7 Ultimate, Home Premium will be fine.
Need to know what you will use it for and what resolution your current monitor supports.
When you have a final spec, give ocuk a call and they will price building it for you, may take them 3-5 days to do it once all th parts are in stock.
Monitor is fairly new "Samsung" don't have access to details at present.
Computer will be used for general pc use, photo editing and a bit of gaming.Usually being used 24/7
If i can have help with my build and does anyone know what overclockers generally charge for building PC's?
Thanks
Seems to be a big budget for what you will use it for.
General use to me = internet and office, any £300 pc will more than do this job.
Photoshop, not an expert on how much of a system hog this is, but i imagine something about £800 would be more than adequate.
Gaming, any £800 pc will play any game at a top resolution just fine.
I hate wasting money and really can't see why you need to spank £1600.
Plenty of threads with people looking i5 gaming machines, any of those would suit your needs.
May want to consider throwing in a ssd hard drive to get a bit more performance.
Done a slightly different spec, try overclocking yourself :)
Gigabyte ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card £309.99
(£269.56) £309.99
(£269.56)
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail £211.99
(£184.34) £211.99
(£184.34)
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £199.99
(£173.90) £199.99
(£173.90)
Coolermaster Cosmos PURE Black Silent Full Tower Case - All Black (No PSU) £174.98
(£152.16) £174.98
(£152.16)
LG BH08LS20 8x Blu-Ray-RW/DVD±RW Dual Layer SATA Drive - Black (OEM) £139.99
(£121.73) £139.99
(£121.73)
OCZ Obsidian 6GB (3x2GB) DDR3 PC3-12800C9 1600Mhz Triple Channel Kit (OCZ3OB1600LV6GK) £99.99
(£86.95) £99.99
(£86.95)
Corsair HX 650W ATX Modular SLI Compliant Power Supply (CMPSU-650HXUK) £96.99
(£84.34) £96.99
(£84.34)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £61.99
(£53.90) £123.98
(£107.80)
Tuniq Tower 120 Extreme CPU Cooler Rev.B (AM2/AM2+/AM3/LGA775/LGA1366) £36.98
(£32.16) £36.98
(£32.16)
Sony Optiarc AD-7240S 24x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £18.99
(£16.51) £18.99
(£16.51) Sub Total : £1,229.45 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75 VAT is being charged at 15% VAT : £186.48 Total : £1,429.68
If your going to spend that much invest in an SSD for operating system & programs. Lightning fast. Even a 64gb could do if you dont use any massive programs.
and silent...
Thanks for the spec RJC, £1430 sounds better than my spec, don't think i can push for the ssd as i am about my max now.Does anyone have a rough idea on how much overclockers charge to build a system??
Windows 7 Home Premium is more than enough for you as stated before.
Can't answer that...
Do you want a PCI card or just an expansion hub?
And what are you using the USB's for? Mouse and Keyboard or transferring files? TBH, something like This should do you fine.
I doubt you will need one. Are you going to be doing any recording of music or do you need high fidelity sound? Are you a audiophile?
Thanks
Don't mention it :P
Windows 7 Premium it is then
and the Belkin PCI card is ideal(thanks) just for connecting keyboard, mouse,bluetooth adapter etc, and from what you say, i won't be bothering with the sound card, onboard one is good enough.
Thanks
