Caporegime
- 8 Jul 2003
- In a house
Using Ray Adams ATI Tray Tool utility. The advantage of doing it the alternate way is that the Nvidia card check is bypassed and you get ingame AA rather than AA forced by the display driver. Big deal you are probably thinking but the ingame AA is faster as it isn't done via brute force.
So how do you do it the ATI Tray Tool way?
Install it (users with 64bit OS's will need to sign the driver if you want to use the overclocking part of the app, I just didn't enable that part or any of the clock reading functions as it isn't needed and so that it would work on X64 without messing around since explaining how to sign drivers for 64bit use is beyond what I am going to go into here)
Create two profiles in the ATI Tray Tools app, one for the BmLauncher.exe and ShippingPC-BmGame.exe
In the 'Direct3D Tweaks' option, enable the tickbox to change the adapter identification
In the Vendor ID put 10DE for the Device ID put 5E2 The device description put NVIDIA GeForce GTX 260. Do this for both profiles saving each one before starting the next.
Launch the batman launcher. If you have done it correctly it will say that your Nvidia drivers are out of date (because you are using ATI ones of course) and it will then allow you to set AA in the launcher. After that start the game. Notice that the ingame AA works.
Credit for this goes to Szaby59 although his instructions were a bit lacking so I changed them a bit to hopefully make it clearer what to do.
ATi Tray Tools Here :- http://www.guru3d.com/article/ati-tray-tools-/
Credits to Spyre.
