Hi guys,
It's been a while since I built this computer (in sig), back then I bought windows xp and happily dodged Windows Vista - sticking to the ever faithful windows xp 32bit.
Now however, that I am able to get Windows 7 from Uni for free I've decided its time for the upgrade. Can't resist a bargain!
Of course that brings up a few issues, compatability for a start. I'm assuming that all my hardware components are compatable seeing as they're hardly three years old. But if anyone can confirm that I'd be greatful. I've read a bit about software compatability but it seems that compatability is less of an issue now...right?
Also I was wondering if I get the 64bit version I presume I'll have to do a complete clean reinstall? While that is a slight pain as I've only recently done a clean boot I can deal with it.
But for the fun part; with 64bit I understand that I can enjoy up to 8GB of RAM. My current RAM is 2GB of PC6400. It is also my understanding that my motherboard can handle up to PC8500 but I'm not entirely sure, I can check the manual again when I get home to confirm.
I was considering if it would be worth replacing my 2GB of RAM in order to get 8GB of faster RAM? Or should I simply add onto my current RAM?
Forgive all my questions, I've been out of the upgrading/overclocking/building loop for a while now.
I can supply more detailed info on my rig when I get home if required, I may just do so anyway for convenience' sake.
Hope I'm making the right choice with windows 7, I've heard pretty good things so far.
Many thanks in advance,
Regards,
Josh
PS: I apologise if this should have been posted in the hardware forum, I know it's quite a mix of topics but the overriding subject is of ''windows & other software''.
EDIT: Another issue I've just considered... I've overclocked my CPU and in the process altered the clockings on my RAM. How does this effect me if I want to insert more RAM?
Regards,
Josh
