Thanks mate. Yeah I reckon it's nothing, at least it's not leaking. It did make a gurgle the 1st couple times I powered the system up some weeks ago but nothing since. And it did take me a couple of go's to get it installed with the stock thermal paste so I was expecting the worst. However the pump is operating within specs (around 1400rpm according to corsair), and while the room the pc is in, is warm I think the temps are ok..according to realtemp - 2 cores idle at around 32, the other at 35, and the last at 38. This is at stock 3.33ghz with turbo mode on around 3.5ghz. I only stress the cpu when gaming and mid 50's is all I have seen. System temps dont pass 37 according to Asus AISuite. I am doing a push/pull configuration with the 2 akasa apache pwm fans exhausting at around 1100 rpm most of the time. I could reverse them and use them as intakes as Corsair recommend to see if it makes a difference. Not sure it will though as I have a front 200mm intake and the optional side 200mm intake, so not sure if the air being sucked in and circulated would be much warmer than what I could pull in using the rear fans as intakes as Corsair recommend. Also the only outtake is the top 200mm fan.
