Spec Me a Beast - £1500
9 Jun 2004
I need a beast. The last time I asked you guys to build me one was nearly 4 years ago and alas that PC is starting to get old. The systemwill be used for the daily running of my business so no games. I work with huge spread sheets and do a hell of of a lot of searching and replacing which this PC is VERY slow at, So I want something that is going to open programs at lightning pace and not take ages to do repetitive tasks. I want something that has plenty of storage space and would like possible to have the OS on a very fast hard drive, possibly soild state. I will probably be going down the Windows 7 route as well with this. I already have a Mouse, Monitor, Keyboard so the rest is up to you guys.
Many Thanks in Advance!
:cool:
Here you go bud, you can change a few things and udner you budget too. You can change things if you wanted to like the case or get an aftermark cooler for better cooling.
My effort :)
i wouldnt call them "a beast" ati 4550 & 4850 gpu hope you dont want to do high-end gaming...i built a core i7 920@ 3.8ghz on a ud5 mobo 2 samsung f1s raid 0 and 2 4890s in crosfire in an antec 1200 case for less than £1500 ..you dont say what you mainly want to use the pc for but if its gaming then them 2 specss have a major malfunction...
for £1500 with no gaming you can pretty much pick the most expensive item in every category required except Graphics. Happy days;)
We can remove the copy of Windows 7 as I have a copy of that already. Also I have a spare Sapphire ATI Radeon 2600 Pro 512MB which I Initially bought for the media center but realised I didnt need it. So Would this card be good enough for the beast? I know I said no gaming but I want to be able to view stuff in decent clarity.
Also Coupe any reason you went for the double SSD instead of 1 single and 1 Normal like Ben?
My current PC has 1 x 80GB and 1x 200GB drive and they are both rammed so I think Bens combo should do the trick.
Remeber I probably wont be buying another PC for at least another 4 years so it has to be able to stand up to the next 4 years of abuse.
We have both gone for 2 SSD's :confused:
RAID 0 for the 2xSSD's for speed, RAID 1 for the 2x1Tb drives for data redundancy.
here is my effort. you can add your old screen to the system and go dual screen. It really helps speed things up rather then minimizing and maximizing a lot from a personal point of view.
if however you don't want to go for this or stick with just 1 screen, then remove the screen from list and total comes to less 450. ( or could go for a cheaper one?) up to you!
shave some money and go for a cheaper mobo - ud3 or bloodrage gti would be my suggestions. 6gb of whatever ram is cheapest is plenty for now as I wouldn't OC at all.
For storage 1 ssd for OS, 1 for programs. Budget too small for redundant RAID array and I wouldn't want to risk losing any data off my work machine for the sake of speed. SSD's are quick enough already. Add two 1tb drives for bulk storage - use 1 and the other as a backup maybe.
stick wit ha relaible psu, modular is fine despite some persistant rumours to the contrary. If shopping at OCUK i'd suggest one of the HX corsairs.
craig
If someones got the money to spend then let them spend it.
If some people want to make savings then so be it.Who are individuals on here to comment on what people should or shouldn't spend:rolleyes:
From what little time i have spent on this forum it seems to me that people in general are after advice from the more knowledgable,they tend to give a budget and if they are prepared to spend more or less they tend to do so;)
