new laptop screen
29 Apr 2007
Cambridgeshire
not sure i can ask this here? if i cant then i am sorry and will close the thread. not sure if it this counts as asking about competitors! i dont want a ban and will close right away if told to.
My girlfriend has a advent 7090 laptop and the screen has a big crack going through it, i want to replcae the screen but have no idea where to get one from. is there an advent uk spears number or anything?
or if i can get one thu overclockers then great
thanks,
and sorry if this is against rules ocuk.
i assumed it would have to be one made for this laptop didnt know other ones could be used. when you say the harness on the back matches do you mean that i need to open the laptop up and i should be able to see how it fits on?
hi, i have got the old screen out and its model number is ht140wx1 and its a 14" screen not 14.1" so am i right in thinking that the one beermonster told me wont work?
thanks.
thanks.
... there's 1 on ebay now ..not a screen bt full laptop... be worth getting if its no more than 50 pounds that way u got spare everything .... and also cud double the memoery in it :)
thanks.
Sorry my bad, i did search for advent 7090 and the first review said it was a 14.1, so no it won't fit, there are some of the ht140wx1 on ebay but not cheap.
