Periodic loss of aero in windows 7
12 Sep 2007
Every so often windows would revert to aero basic for no reason before going back to full aero effects.
The graphics card (260-216) makes a whining noise before returning to normal.
Any idea what's going on?
It's definatly not happening because of programs you're opening?
I know 3DMark Vantage will make aero turn off, aswell as certain versions of MPC(or it might be the realmedia codec, not sure).
If this isn't the case then ignore me, just remembered about Vantage when you said you'd updated your graphics drivers.
It could be winSAT that has started when it was scheduled, to disable it
1) right click on my computer then click manage
2) goto Task Scheduler (click Here and navigate to the one highlighted)
3) right click on the winSAT then disable or delete it.
That should cure it from doing a random test at night.
