I love this case but the fans are so damn noisy that I need to replace them asap. Things is though, the stock fans have dimensions listed as follows:
When buying new ones do I base my purchase on the largest dimension listed above, which if so, would put me in the market for three 230mm fans and one 140mm fan?
If thats the case I see OC's don't have any 230mm fans for sale, the closest being 220mm. Will they fit in the case or might the decrease in size make them a little loose?
Also, is fan size important when it comes to cooling? Is big actually better?
I've never changed fans so I know little about this kind of upgrade. Sorry
Front: 230x30mm red LED fan x 1 / 700 rpm / 19 dBA
Side: 230x200x30mm standard fan x 1 / 700 rpm / 19dBA (supports 120mm fan x 4)
Top: 230x200x30mm standard fan x 1 / 700 rpm / 19dBA (supports 120mm fan x 3 or 120mm x 1 + 230x30mm x 1)
Rear: 140x25mm standard fan x 1, 1200 R.P.M, 17dBA
