I had been having problems with 5850 'VPU recover' kicking in at idle speeds, in Win7-64bit. Same idle issues occurred in XP-32bit. Thought I had it fixed after updating the motherboard BIOS, and all the system and graphics drivers (Cat 9.10).
However, because I only had a Corsair HX450W PSU, I thought I would replace with a Corsair HX650W PSU. So fitted the new PSU and all the cables. Only difference being the 650W has 2 PCI-E cables per PSU connector, 450W uses one PCI-E cable per PSU connector.
Win 7 booted fine, then system completely froze. KB + Mouse locked, no response. Rebooted, and system froze again after a couple minutes. Checked all cables - connected fine. Reset BIOS, system ran fine... Played Crysis and Bioshock demos on max settings - ran great. Unigine Heaven benchmark, which usually runs fine, crashed to desktop mid way. Re-ran, then got a brown/grey screen, and system freeze.
Rebooted and ran Heaven again - ran fine.
Before at least it seemed like a driver crash. The system freezing now seems to be happening in place of the driver crash (or VPU recover), but obviously more serious in that I have to hard reboot!
Anything to try?
Anything to try?
So I take back my last statement - something is critical with the PC (my guess is memory or very flaky GPU at this point).
