I dont know much about CVT, if they are the answer why are manufacturers still pouring money into automatic boxes? (Genuine question)
I think it's because most CVT boxes will have the previous stigma of being unreliable and having the "rubber band effect" as with the old CVT boxes (DAF etc). But the Nissan one I drove was very nice, the CVT attached to the Jazz seems to have positive reviews as do the Audi Multitronic boxes, and they seem to be becoming much more reliable using steel instead of rubber belts etc.
I think another reason against them is that as people grow up, cars accelerating has always been associated with a rise in revs, then the fall as the gear is changed, and it is a weird sensation driving a CVT where the revs barely rise yet you still accelerate, or where you floor it, the car accellerates, as does the engine up to peak power (usually around 6k rpm) and then stays there whilst the speed catches up. It feels (and sounds) like a slipping clutch would and is a peculiar sensation to get used to.
They offer massive benefits IMO, particularly with motorway driving, as they seem to allow a higher top ratio, allowing you to sit at high speed with as low rpm's as possible. And if they approach an incline, rather than booting it, the CVT box reduces the ratio slightly, the engine smoothly speeds up to provide a little extra power rather than having to force the pedal down and induce kick down.
Again, I've not driven a high end car with a very good auto box so I can't comment, but it's very smooth. The same goes for on cruise control, rather than it taking a couple of seconds for the car to realise it needs a lower gear to keep the car at speed, and then feeling the change and surge of power, it seemlessly stays at speed with only a slight increase in engine note.
I think the main reasons are for now, getting the reliabilty topnotch. Modern CVT boxes are still relatively new technology (to be able to handle modern engine power anyway) but I think manufacturers are getting there, and I can see (or at least I hope) CVTs replacing traditional planetary auto boxes!
