Any one using water cooling in a Cosmos RC-1000?
6 Dec 2007
cambridge
At the moment i have my i7/UD5 fitted in the RC-1000 and being cooled by a coolit freezone elite.
The freezone elite is a great bit of kit and i can bring the temp of my cpu down at the click of a mouse, although i think it may be just a tad over the top for my 3.6 Ghz clock!, (i have no intentions of going higher as i mainly use the thing to check email!:D)
I have been thinking about fitting some sort of custom water cooling set up instead as it seems like a great project to undertake and want some advice on what parts to go for.
I appreciate the case is not the best for cooling in the world but i really like it and so any advice would be much appreciated on an ideal watercooled setup for my rig.
i think you can put a dual RAD in the floor and a triple in the roof with some modding, will try and dig out some pics for you.
i think a dual rad in the roof would work-based on the fact i would be cooling the I7 920 DO 2.66 at no more than 3Ghz ish;), any rad suggestions to look at? Also wondering if a combined pump/res would be a good idea?
