Edit hosts file to avoid typos
7 Mar 2005
LU7
Every so often I'll type 'fm' or 'gm' say for my Fastmail and Gmail into my browser but I'll accidentally press CTRL+ENTER and rather than Opera going to fastmail.fm or gmail.com I'll end up and www.fm.com or www.gm.com.
Now I know I can edit my hosts file so that if I end up doing the above and going to www.fm.com or www.gm.com etc that I can get myself redirected to fastmail.fm or gmail.com. :) Problem is I don't really know what I should do, i.e. what I type and in what order. :confused:
Can anyone help me?
i use a handy feature called "bookmarks". they've been quite popular amongst various browsers for some time now. for regularly used sites, you might want to give them a try. :D
editing hosts files is for the translation of domain names to ip addresses so they are of no use to you in this situation.
so to address your problem, maybe look at using opendns as that has typo correction. not used it myself but it's listed on the features page here....
http://www.opendns.com/start/
If you use OpenDNS for your DNS servers I'm fairly sure that by registering for a free account with them you can enable type correction and things like shortcuts.
That's enabled but if I type fm it won't work. It is only if I type google.cmo say.
windowsfolder\system32\drivers\etc
You wan the hosts file. Open it in wordpad or your editor of choice, copy the format of the entries already present.
For example to resolve fm.com to 123.123.123.123:
123.123.123.123 fm.com
Job done, be aware though - This might break some sites.
If running Vista or W7 with UAC you will need to load up Notepad using the "Run as Administrator" option otherwise it won't let you save your changes to the Hosts file.
