Just had Sky HD "installed" and its not working... Here's the full tale of events:
I previously had a standard Sky box and another standard Sky box (multiroom). I phoned sky to upgrade my host box to Sky+HD and the other box to Sky+. So skip foward to today and the engineer came out and installed the dual coax cables and setup the multiroom Sky+ (non HD box). All worked well, all features were availible immediately, but the host box (Sky HD) is a different story all together...
He went though the usual setup process and proceeded to try the call back which failed numerous times. In the end he said my phone line must have a fault as it won't do a call back. He said Sky could do nothing and BT need to look at the fault. I asked how this was possible because the other box went into the same phone line and worked fine! :S He waffled on a bit and left just advising to "call BT".
When he left I decided to go for a bit of trouble shooting. I plugged the phone line which was going from the HD box directly into an ADSL filter and into the main phone point and test using a standard phone - it worked fine. I plugged this into the HD box and went thorugh the setup process and the call back failed twice so I called Sky. The girl on the other end of the line said she would activate it, and after a slight delay she said "It should be fine in 4 hours". Well its been over 4 hours and nothing....
Anybody had this issue before? Or been blown off by the engineers like this before? Any advice would be awesome
