Clock for Clock comparisons of i7 skt1156 & skt1366 with turbo boost off?
What I'm trying to find, is direct comparisons of the i7 860 or 870 against the i7 920, but with turbo boost turned off (as it will skew the results as the turbo boost on the skt1156 i7 is more aggressive) and both processors running at the same clock speed (something like 3.4GHz would be good).
None of the comparisons I've read seem to show a direct comparison of each platform with the processors running at equal speeds and no turbo boost.
Also I would quite like to see the power draw of each platform as the skt1156 i7's will most likely need a voltage increase to attain that speed and as has been in some reviews they do start to use a lot of power when you overclock them.
