- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Xigmatek Asgard Mid-Tower Case - Black (No PSU) @ £29.99 inc VAT *** ***
The Asgard case is the first entry-level chassis with a black coated interior. Furthermore it is supplied with 1 x 120mm pre-installed black fan, and 3 more fans can be mounted in different area for best possible airflow. The 4 x 5.25" bays will be able to house all your optical drives and you can fit up to 5 x 3.5" bays for all the storage devices you need.
- Screw-less tooling for the bay device
- Dust filter behind front panel for intake airflow
- Dimensions: 185 x 475 x 408 mm (W x D x H)
- 4 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- Front Cooling: 1 x 120mm black fan
- Rear Cooling: 1 x 80/90/120mm fan (optional)
- Side Cooling: 2 x 80/90/120mm fans (optional)
- Front I/O Ports: 2x USB2.0, 1 x HD Audio
Only £29.99 inc VAT.
ORDER NOW
ORDER NOW
