This. You don't want a high level of moisture in the house anyhow. It leads to mould.
Modern dehumidifers are near silent and only draw 200w or so in operation. Worth doing, getting one made a massive difference to the comfort in my house during winter. Everything feels warmer and it's nice to wake up to clear windows even on wet days.
Its bad that I saw "Shammy" and associated it with Shaman from WoW.![]()
Get yourself one of these. Can also use it on your fridge, computer etc when done. Is pretty addictive seeing how much power everything uses a dayAny idea what level of cost would be involved in running it for a few hours a day? Draws 190 watt
How is it warmer? Apart from you have a power supply consuming 200W heating up yuor houseBuy a dehumidifier and you will reap the benefits of a warmer, healthier home
Huh? We have a little bit of condensation around the edge of some glass? Not damp walls etc?Warmer - the heating system works more efficiently - no cold damp walls/windows to heat
See above...?Healthier - cold damp environments are not very good for you
And healthier?
you can get moisture absorbing gel that comes in a little box and sits in the window sill
TA DAA!! just need to empty them/replace gel or they overflow
http://www.lakeland.co.uk/moisture-...aning-protecting-de-humidifiers/product/21538
Where do you put your unit then?It's hard to describe, but the lower the humidity in the house the warmer and dryer everything feels. The most noticable thing is the bed, it's just so much nicer when humidity is lower. You also don't wake up with a blocked up nose as you breathe better.
Someone said 'ventiliation' and they are correct in saying that can do just as good a job, but remember if you open your windows on a wet day you will be *increasing* the humidity in the house as you'll be letting in damp air. It's very hard during the winter months to properly ventilate a house.
What I suggest you do is look on a well known auction site and pick yourself up a humidistat; I got one for £7 delivered. This will tell you the levels of humidity in your house. Ideally it should be between 40-50%
I found the levels in my house were often into the 70's, occasionally the 80's when there had been some showers. In a small house this just gets trapped and opening the window on a damp day won't really help.
Getting the dehumidifier has made all the difference for us.
I put the dehumidifier on the upstairs landing. It's the most central spot for air circulation being the warm air rises from downstairs carrying the moisture with it.
