I'm getting a i7 920 system in the next week or so.
Would you recommend that I enable HT?
I will probably use the system for Video Transcoding, Gaming, and some developement work, including running multiple VMs, but I doubt that I would run more than say 4 VMs at the same time and I doubt I will be gaming, transcoding and using VMs simultaneously either.
What performance hit can I expect by turning on hyper-threading on each of the cores?
Got one with two apaches in push pull, running my i7 with HT on @ 4GHz (1.25V) Idles 38oC all cores and maxes out at around 72oC great cooler! Not a lot of games are utalising HT at the moment, some games may even take a slight performance hit, but for video transcoding, etc it does make a difference! Software will eventually catch up so I would leave it on, turning it off equates to around 8oC in my experience. Great CPU, great choice, get a decent mobo, RAM and watch it fly!
