Clean Up/Defrag
22 Oct 2005
Moving...
Hi all.
My gf's mac is starting to run a bit choppy, it sometimes freezes just looking at web pages on the internet and in general it's just a lot more sluggish.
I know nothing about mac's I'm afraid, but if it was a PC I'd just run a disk defrag and Ccleaner to tidy up old bits and pieces.
Is there any kind of tools (either pre-installed or free to download) that can are equivalent to this or will just give it a bit of a clean up?
Cheers.
Go download Onyx and run through the appropriate options (mostly cache rebuilds). Defraging an HFS+ volume won't do any good.
What version of OS X is she running?
Just downloaded CleanMyMac and iDefrag as per your suggestion. Never used these before so thought i'd give em a try!
Just found about 7GB's worth of application caches and some programs that i don't even use anymore have huge caches of 2GB's! Will see if iDefrag makes any difference. I was under the impression that defragging was not needed as HFS is an awesome file system! :p
Thanks for the replies.
It's a four year old PowerBook G4. It has a 74GB hdd with 22GB of that spare. OS is Mac OS X 10.4.11.
Sounds like defragging isn't really worth it. I had no idea that mac's use a different file system.
I'll give that Onyx a go though. Is the cleanmymac app worth a look too or does it do much the same thing?
Last thing, I've downloaded OnyX 1.8.5 which looks like the correct version for this OS. Any options I should definitely run or not run?
Thanks.
Woah, iDefrag seems really involved. There doesn't seem to be a definitive Snow Leopard walkthrough yet so I think i'm gonna wait before trying that!
Anyone here keen to try the software? You have to make a bootable SL disk and defrag the original disk while it's offline...
It isn't but somepeople who come from a Windows background get the itch and so people make the software!
Ain't that the truth.
Took me months after switching to realise that but since then have never looked back.
I run the various tasks in Onyx about once a month (Cache rebuild, etc), Everything else is software for the naive Switcher; used to having to nursemaid Windows into some semblance of speed performance.
iDefrag does support Snow Leopard [1.7.1 (226) ].
I have been using it for a few months via a cloned copy of my OSX system.
I'm having a look with iDisc at my external drive.. it's not going anywhere near my SSD system drive!
Ok, with about 259GB of data:
7,485,524 files of which only 238 files are fragmented.
3,005,685 data forks of which, unsurprisingly only 238 are fragmented.
236,236 resource forks with 0 fragmented.
So in short defragging isn't worth it!
You're much better giving the system clean up routines a poke to free up drive space.
What steps did you take when creating a cloned copy of your system?
You used the CDmaker software i gather?
I inserted my Snow Leopard disk and started to create a copy but was unsure it would be wise using that as my disk is 10.5 whereas my system is 10.5.2.
Thing is, the reason i want to defrag is because iDefrag says i am 33% fragmented. I did an online defrag and it took it down to 0.03%? Will check again in a sec and see what it says.
I use SuperDuper to clone my system on a daily/weekly basis plus Time Machine every hour.
This enables me to run iDefrag from an external hard drive.
Did an "Optimal" defrag yesterday - it took about 4+ hours for my 320Gb internal macbbook drive. Significant speed improvement. But I also did an Onyx maintenance, so I don't which or both was more influential.
