Hi all,
I know theres a bit of interest with this motherboard on here, but I wanted to mention a few issues ive seen to make people aware, and to see if anyone else has this problem. I will be contacting Foxconn to get a response from them as well.
The first problem I encountered with this board is that the if you use Windows 7, then the CD with the drivers on appears blank. It works fine in Vista, but you can get the Intel x58 drivers for Windows 7 on the Foxconn website.
Im getting lockups in Windows and mainly when using Steam, havent managed to track this down yet (Event Viewer shows no problems).
The utilities that come on the disc look really poor. The Aegis Panel 2 software which gives the fan speed and temp info looks like it was designed by a 10 year old!
The LiveUpdate for updating the BIOS works well, however I updated my BIOS to P08 rebooted the PC and windows had to detect all the drivers for every device again! never seen that happen with another motherboard?
The 1600Mhz RAM I have is detected as 1067Mhz.
The Red Force Reset button on the motherboard doesn't really seem to help with anything, just reboots the PC.
The biggest problem I have is when overclocking you chance a setting in the BIOS called "System Turbo" You change this to Enable and it gives you access to the overclocking features. If this is changed and any kind of overclocking features changed you reboot and get the message:
"AHCI BIOS not installed" along with "WARNING! Over clock recovery occur. Starting in Safe Mode now"
You have to go back into the BIOS and put settings back to default.
Some other people over at overclock.net had the same problem and you have to disable the following:
BIOS > Quantum BIOS > OC Gear > Disabled Over Clock Recovery
This then allows you to make an overclock.
Following the overclocking guide over at XtremeCPU, I haven't hit the 4GHz overclock. The PC wouldn't even post. I have managed 3.6GHz, but will pursue this to see if I can get better.
I cant help but feel I wish id gone with the Gigabyte GA-X58-UD3R motherboard.....
In Summary, has anyone had any of these problems? and what settings have you changed to overclock yours?
