As above - is this CPU still current ? Hard to keep track of CPU releases these days
Buy a 920, you will easily get a 4GHz overclock, and 1600MHz RAM speed on it.
Yes I know and I've considered this option. However I need 12GB RAM (virtual machines etc) and hence I'm not expecting to get 1600MHz and due to the extra stress with 6 sticks I thought that the higher CPU multiplier would be the way to go for a safe and low hassle 24/7, 3.4-3.6 GHz overclock.
Simply put, buy the 920, up the BLCK, and if you have problems with the RAM speed, lower the RAM multiplier.
