Are they still not making any available?
The game simply doesn't support dedicated servers anymore despite promises. They went their way out to remove the support completely and replace it with a P2P matchmaking system.
just realised the discs inside have the BBFC rating on them not the PEGI rating which proves they are UK discs so it looks like they have just put the UK discs and UK booklet in a non UK case. So I guess the "non for sale in UK" is nothing to worry about after all !
no dedicated servers, no lean, no mods, 9v9 max per 'server'.
exactlyContent? what?
Well....that was stupid of them
.It might not work, im sure steam have a strict policy with activating foreign games
I'm guessing that most people on here are aware about the release activation date, so I can't see what your point is in that regard - it's no different to if you could preload it via Steam beforehand - you'd still have the content but not be able to play it until the day of release.
Just to say the key validated fine for those still wondering - all for £23.99 inc VAT. very pleased with this.
Same here, activated fine and played 40mins of it already.
Just got mine now slighty confused ive just created a steam account and now its downloading from steam but i got the disks so why is it downloading from steam which at my interent speed is going to take 12 hrs.
Tried putting in the disks and running the setup from them? That's what I did, it installed from the disks that way. Otherwise it will take ages as it is 10GB+.
