*** *** Samsung Series 7 UE32B7020WW/XXU 32" Full HD Ready LED TV with Digital Freeview @ £699.99 inc VAT *** ***
For images that are stunningly true to life you need the 3 C's: contrast, colour and clarity. Its Mega Contrast Ratio feature brings out all the shades of grey as well the shades of amber, fuchsia and magenta. A Wide Colour Enhancer pro with LED gamut ensures every pixel is robust and vibrant. Plus 100Hz Motion Plus technology removes edge-blur. Leaving your picture smooth and crisp. Unlike other "slim" televisions, the LED 7000 is one of the slimmest television in the world. Instead of multiple parts molded together, it's one solid, seamless, incredibly beautiful advanced television. Elegantly supported by a unique crystal neck. You'll have no trouble finding a place for it in any room.
- Screen Size: 32"
- HD Ready (480i, 480p, 576i, 576p, 720p, 1080i & 1080p Supported) (Sky HD, Virgin V+, Xbox 360 & Playstation 3 Ready)
- Resolution: 1920 x 1080
- Mega Dynamic Contrast Ratio
- Digital Tuner
- Analogue Tuner
- Supports 1 Tuner PIP
- EPG Programme Guide
- 4x HDMI
- 1x Component
- 1x Composite
- 1x SCART
- 1x PC VGA
- 1x PC Audio Input (Mini Jack)
- 1 x Ethernet Port
- CI Slot
- Wireless LAN Adapter
- 2 x 10w Speaker System
- Down Firing Speakers
- Dolby Digital+ Support
- Vesa Compatible
- Dimensions: 813 x 584 x 240mm (With Stand)
- 1 Year Warranty
Only £699.99 inc VAT.
ORDER NOW
- Screen Size: 32"
- Digital Tuner
- Analogue Tuner
- 4x HDMI
- 1x Component
- 1x Composite
- 1x SCART
- 1x PC VGA
- 1 x Ethernet Port
- CI Slot
- Vesa Compatible
- 1 Year Warranty
ORDER NOW
