http://www.telegraph.co.uk/expat/ex...hnology-to-bury-greenhouse-gas-emissions.html
looks like the japs are hard at it, pump the bad gas into the ground.
FAR from the "only problem", but yeah that sounds like another
Yeah, 20% may be more realistic, they were better than I thought. That's exactly a poor enough efficiency to completely negate the 5 times stronger solar energy in the first place mind! Not to mention transmission losses and the losses in turning the laser energy back into electrical energy on earth (probably boiling water and driving turbines the usualy way?). It remains pie in the sky for me, no pun intended![]()
There's just the small problem of getting it up there
Good space panels these days are say 300w - so if we can get 5 times that off them (Lets be doubly generous and say we can get 3000w off one panel - which weighs in at 35kg - and is 2m across) - still means we need to get over 3000 of them up there and connected together.
The small problem of 3000 panels being a damn heavy payload for a rocket or rockets and that wouldn't include the extra weight needed for the supports/struts and electrical equipment needed for the project.
That cost alone would probably be more than NASAs total expenditure over the last 20 years -and the maintenance (connecting them together successfully - and as has been learned from the amount of time the reasonably small array on the ISS has had to be repaired due to mechanical failures and particle damage)
And the small fact they they will only be giving out around 85% of their original power after 25 years (assuming all the cells on 3000 panels are still intact and connected - which is highly unlikely).
And as for beaming 1 Billion watts down to earth and being viable.....![]()
Solar power doesn't seem like an effective answer to global power requirements, the odd offset here and there. if every roof in the country was covered and we had a decent way to store the excess power and run household appliances off them we migth have a shot. The other problem being manufacturing, it would take decades and a MASSIVE cost to produce enough panels to cover every roof in the UK, and it still wouldn't be enough.
Will need a massive extension cable to get power back to earth![]()
Covering every roof certainly seems a better option to me. .
You know we'll buy one 6 inches too short![]()
Trouble is localised energy falls flat ion it's face as soon as you get dense populations. The normal parents and 2.4kids in a semi detached house is very good. But as soon as you get apartment blocks, sky rise buildings and dense population. It's pretty much useless.
However I've said all new Houses should be fitted with solar water heaters at the minimum
So this thing will produce 1GW, the figures just don't add up, l.
Covering every roof certainly seems a better option to me. As you say, not particularly viable right now, but surely more practical than launching them into space! Looking at the plus points, localised energy production means no grid losses and higher dependability (and, though hopefully not something which needs to be considered, far less open to attack).
Roof mounted wind turbines do exist too, though I can't help thinking even the magnetic levitation ones will be noisy.
I had thought that if everyone had thier localised energy source, the grid would then be used to interconnect them and help spread the loading more effectively as well as covering any individuals downtime. Furthermore, it could possibly be used to link back to large energy storage units for night time energy, the individual then paying a smaller amount to the grid for this service. I don't know on the second part, localised storage may be more viable here too, just that current methods with batteries do need special maintenance and considerations.
It's research, Fusion is not cost effective or viable at the moment. but we are researching it.
You can't really comment on the cost effectiveness of fusion as it's still in development![]()
So it's only planned to produce 1GW or power? All that effort for that? you get single coal fired powerstations producing almost 4 times that.....
I'm doing my final year project on alternative energies, focusing mainly on fusion. For the mid to long term it's the only real source for base load power generation. When petrol, diesel and gas are eventually phased out the demand for electricity will be huge compared to today.
