** IN STOCK ** Be Quiet! Straight Power Supplies **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Be Quiet! Straight Power E7M 680W Modular Power Supply @ £117.99 inc VAT *** ***
THe new E7 focuses on the high end user who demands the latest in performance and compatibility with the latest ATX 2.3 technology.
The new, elegant STRAIGHT POWER E7 design with a top-quality surface and innovative ventilation grate provides better air circulation and rounds out the product's appearance. That means that STRAIGHT POWERE7 is naturally a worthy addition to the accustomed premium quality of the be quiet! family.
- Features a BeQuiet Silentwing 120mm fan
- Modular Cabling
- 4 PCI-E connectors
- 80 Plus Bronze Certified
- High Tech German Engineered
- 3 Year Warranty
Only £117.99 inc VAT.
ORDER NOW
*** *** Be Quiet! Straight Power E7M 580W Modular Power Supply @ £88.99 inc VAT *** ***
- Modular Cabling
- 3 Year Warranty
Only £88.99 inc VAT.
ORDER NOW
*** *** Be Quiet! Straight Power E7 700W Power Supply @ £112.99 inc VAT *** ***
- 3 Year Warranty
Only £112.99 inc VAT.
ORDER NOW
*** *** Be Quiet! Straight Power E7 600W Power Supply @ £89.99 inc VAT *** ***
- 3 Year Warranty
Only £89.99 inc VAT.
ORDER NOW
Really need a new PSU. mine is only 3 weeks old but too noisy.
would the 400W (Be Quiet! Straight Power E7 400W Power Supply) be enough for my specs. dont want to spend too much
is there a way to test to see how much wattage i need? as far as i know theres not really any guides out there.
also does my current 650W PSU use 650W of power all the time? ive moved out of my parents house and now i pay the bills :D
You can get a meter that you plug in and plug your device into which tells you the wattage being consumed.
The PSU will only supply the power demanded by the components connected to it, it will draw more than this from the wall because of it's own efficiency.
Your pc would be fine with a decent 400W supply but it will cost practically the same on leccy using the 650W you have already.
