Looking to bring in my sub from my car its a FLI 12" active has a built in amp, but apart from that thats all i know, without DIY and faffing with a PSU are there any other easy ways or kits i can buy to get it straight onto my pc?
Not really, most amps have their own power supply which converts 230v into +-DC rails for the amp.Its going to need a power supply regardless.
Not really, most amps have their own power supply which converts 230v into +-DC rails for the amp.![]()
Oh, wait, you mean to tell me that the OP is referring to a 12v sub? I thought he was referring to an active HT type sub! I guess that makes sense... In that case, don't wire it up to the mains, it will go bang!I'm dubious, low voltage DC amplifier step up to 230 AC (flip/flop??) and back down to 12 DC. Car subs I've seen take the 12 DC direct. Could be I suppose not looked in years, but sounds very odd to me.
Can't hurt to try though, specs say the FLI is 300W RMS I'd suggest a power supply with at least 25A 12v rails or more.
I've heard SVS subs before now, the one I saw looked like a long tube and did give off a nice rumble!Mike, you've not heard of BK? They make the best value entry level HT subs. SVS make the best value high end subs period. The pc13 ultra is a pure weapon lol.
To answer your original question, this is what you need to power your sub from the mains:Im so confused, can anyone summarise whats been said and what exactly i need to get?
I've heard SVS subs before now, the one I saw looked like a long tube and did give off a nice rumble!I don't remember the model name tho...
I haven't heard of BK until now, but I'll have a google or two... Most subs I've heard from the more mainstream speaker manufacturers (Mission, Morduant Short, etc.) leave something to be desired...
I've tested car subs indoors once or twice and wasn't very impressed with the results. I also wonder about the quality of the driver & amp in something like the FLI, mainly its low end response. More of a thump thump thump to impress in the cars small resonant volume. My SVS has a tuned extension, down to 20Hz before it drops off. I find the extra low end makes all the difference compared to other subs I've had.Mike, you've not heard of BK? They make the best value entry level HT subs. SVS make the best value high end subs period. The pc13 ultra is a pure weapon lol.
fornowagain remember that a decent ported box tuned low intended for home use will big big, very big for 12" + driver. boxes can get away with being a lot smaler when designed for car use because room gain ect. A small ported box will sound quite average in the average living room.
for me, its either a big ported box tuned low, or a big driver in a much smaller sealed box.
Good point, not exactly class D. With the current available I doubt the designers pay much attention to efficient amplification. There is a chap on youtube running one on a 16A computer psu, god knows how long that would last. Fuse rating would give a better idea.300w RMS output...in reality the car amp would probably be working at some awful efficiancy figure so i'd reckon you'd need closer to 45-50 amps of current available.
Hi but what about the already built in amp i have?
Gotcha, I'll keep that name in mind if I'm ever after a compact sub... Right now I'm happy with my coffin sized thing!The reason you may not heard of bk before is you can only buy BK subs directly from BK, and BK is quite a small company.. If you browse on AV Forums, ppl are always talking about BK subs and recommending them.
That amp made to run from a cars electrical system, which is different to mains electrical system. You could also use a car battery in the house, I've done this in the past when fixing up car amps, it's handy to be able to test them without having to plug them up to the car each time.Hi but what about the already built in amp i have?
