** New Case on the Block **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Zalman MS1000-HS1 Tower Case - Black (No PSU) @ £106.98 inc VAT *** ***
Introducing Zalman latest tower case, the MS1000-HS1. The modular front bay design differentiates this case from the crowd and smooth rounded edges of the case add to the overall quality. The Internal cooling is designed for hot air inside the system to be expelled as quickly as possible to maintain optimum temperature for stable system operation.
- Motherboard Compatibility: ATX & Micro ATX
- Rubber Mounted Feet to prevent vibrations
- Dual SSD Mounting bracket (fits in a 5.25" bay)
- 7 x 5.25" Drive Bays
- 3 x 3.5" Drive Bays (Hot Swap)
- Top Cooling: 2 x 120mm/140mm fans (1 x 120mm included)
- Bottom Cooling: 1 x 120mm/140mm fan (optional)
- Rear Cooling: 1 x 120mm fan (included)
- Internal Cooling: 2 x 92mm fans (1 included)
- Front I/O Ports: 2 x USB2.0, 1 x e-SATA, 2 x Audio
- 2 Year Warranty
Only £106.98 inc VAT.
ORDER NOW
quite like the look of that, damn shame it's made of plastic & steel, and not Ali tho. still, not a bad case all the same. some nice design touches. clicky clicky
As already mentioned, no black internals is a shame, it would sell a lot better with them. Looks very well thought out, and close to a great case if the HDD area was removable, say in two sections so you don't need them all in there at once.
Who the **** is going to need that many drive bays?
Two for DVD Drives.
One for a Res.
One for a fan controller.
One or two for suspending hard drives.
I seriously can't think of anybody wanting more than that.
looking lush and good, silent features and lovely modular slide in hdd trays for the front and plenty space...
Good too finaly see some cases move to 120/140mm fans right now it would be this or the fratual case :)
But would be nice too see more pictures of internals and features of this case.
Totally agree. Looks like a good solid case, but some internal shots would be nice. :)
Look here for a bit more detail.
Having had a more in depth look at this case, it seems very nice indeed. Just the non-black metal internals letting it down (though really it's not a big deal as there's no side window).
Like the cooling, the quality seems good as most Zalman stuff is, and lots of nice features to boot. I look forward to seeing some build and proper reviews.
