USB Memory Stick > an LCD Tv
23 Feb 2004
Manchester
My thinking is to try the following, but would it work?
Copy media onto a memory stick and plug it into an LCD using a USB > HDMI cable/connector.
Even if I could play the media would I be able to hear the audio?
no
you need a way of sending an audio / video signal. USB memory sticks dont do this.
You could buy a HD tv that has a USB slot for playing media though. Sony / samusng and a few others have this functionality.
My TV has a USB port but only plays MP3 or JPEG files.
My Samsung DVD/Home Cinema also have a USB port and can play media files up to 1gb in various formats (DIVX etc) so it might work throught your DVD player if it has a port.
Out of intrest which TV is it you have that will only play the JPEGS and MP3s? As if it's an LG there is a very easy way to enable divx support.
Samsung LE37. But it doesn't matter as I don't use the TV slot anyway as the Home Cinema one does Divx :-)
