However, these resolutions are used because of TV/Blu-Ray signals that use these specific resolutions. Monitors are available in a variety of other resolutions, all of which can play these signals fine, they are simply adjusted to play on the different resolution by the PC.
"HD Ready" is not just down to the resolution of the panel, it is also down to what inputs it has and whether they are HDCP enabled (I think).
Therefore a 17" monitor with VGA input is not necessarily "HD Ready", but it would be considered HD. There is a difference.
Technically anything that is 1280x720 can be "HD Ready", but for a monitor this is considered rather low resolution.
So technically, a 17" monitor, or 15" come to that matter is still considered HD? I.e It can play Blu-Ray quality. Obviously the size is shrunk but it can still play HD
Sorry, what is HDCP?
