Just spilt a fair amount of orange squash on my iPhone
Dried it with a towel and turned it off ASAP, before I turned it off I noticed that the "This accessory is not designed for.." box kept coming up and the volume slider was gone from the iPod bit.
What should I do now? Leave it off for a few hours to dry out?
()Dried it with a towel and turned it off ASAP, before I turned it off I noticed that the "This accessory is not designed for.." box kept coming up and the volume slider was gone from the iPod bit.
Then you will change ALL the water sensors purple, and you're knackered.
