The faster a fan spins the easier it is to see through it. Also that pic could be a result of shutter speed of the cam, ive taken pics of my system running and you would think the fans were static in the image when they weren't.
is it just me but doesnt look like that fan is spinning
I can't believe were debating if the fan on a Nvidia card is spinning or not, their rep gone down that bad..![]()
Your right my mistake, but surely you would be able to see the board through the whole thing then, and just through a little gap on the right.
Its possible the fans setup like it is in the gtx 295 with a semi circle cut out of the pcb to allow the card to intake air, behind that the pcb is whole again so you can't see through.
Yeah probably, i can't see them saying they showing a working card running a benchmark, but its actually not switched on, as not plugged in or nowt, and they really got a hidden setup with a card in behind everything out of the way thats running.![]()
Yup, you can see the mobo through the blades on the right![]()
Nobody seems to have spotted the Microsoft Mouse and Random Keyboard which is hiding behind the Dell Screen (bottom left of the photo)
For all we know that might be a second computer running a Radeon 5870 feeding the Dell monitor![]()
be interesting to see what figures these puppies give
The fan only comes on when it gets above 40C![]()
Is that two 8 pin PCI-E connections ???
