Na nowhere near as big, the 5870 goes past a standard ATX mobo by about 3 inches, this fermi pic shows it to be about the same length as an ATX mobo.
Indeed
A pci-e slot in real life is 11.65mm so the card is 44.27 mm long or 17.4"
there may be flaws in my calculation such as perspective![]()
It is? Looks like it goes past to me?
Measuring from the photo the pci-e slot is 25mm long and the card is 95mm long.
If they were using the rampage II extreme as it said it was, thats an e-atx board and it looks to just go slightly off.
is it just me but doesnt look like that fan is spinning
How much wider is the rampage 2 compared to a regular motherboard? I was actually considering an rampage 2 in a lian li v1000z, not even sure if it would fit now =/
It's an extra inch.
I agree. I just zoomed in on the image and that fan is static.
Or that you somehow turned 4.427cm into 17.4".![]()
Yup, you can see the mobo through the blades on the right![]()
If it was spinning fast enough though, then you wouldn't see through it would you, so how fast is that one going, 1 turn a day.![]()
