I decided against becoming reliant on addons actually. I got fed up with having to update them all all the time. Now i stick to bartender, pearl unit frames and quest helper (i know QH is cheating, but jesus it saves time).
The default UI is nice and all, but it takes up so much space if you need more than 10 buttons. I'll try and find my UI.
That's from before WOTLK and "The Great UI Purge of 2009". Can't find a recent one :/ I'll take one later.
what addon you using to show the buffs like that?
Elkbuffbars - http://wow.curse.com/downloads/wow-addons/details/elkbuffbars.aspx
Using a texture from the SharedMedia addon also I believe. Just modified the colors and layout.
Might be able to sort out a Saved Variable of the layout u can use if interested.
i had that but when i put a buff on the timer froze and wouldnt count down :/
edit* just tried again and when i try to configure it to set what to show and what not, nothing i click gets selected i dont no whats up with it. if i click buffs to show buffs has a bullet point but if i tick debuffs it wont put a bullet point next to it.
i installed it using the curse client, and yes im using win7, not had any problems with any other apps but i will try running the launcher as admin
