Are you smarter than a Singapore P6 student?
10 Nov 2004
Expat in Singapore
The Primary year 6 exams here have been critizised quite heavily here for their difficulty.
P6 is for 11->12 year olds.
An example from the maths test paper;
Jim bought some chocolates and gave half of it to Ken. Ken bought some sweets and gave half of it to Jim. Jim ate 12 sweets and Ken ate 18 chocolates. The ratio of Jim's sweets to chocolates became 1:7 and the ratio of Ken's sweets to chocolates became 1:4. How many sweets did Ken buy?
How does this compare to the current difficulty in the UK for the same age ?
I don't remember primary school being this hard....
RB
I'm at university doing computer science and I can't be bothered to work that out, what does that say :o
It is really early though
It says you need to write a program to do it for you.
Ken bought 68 sweets by the way.
is it not just a quadratic equation? which used to be pre-gcse, moved to just gcse higher and I've a feeling have started getting lower again, either SAT or lower.
I suspect that's more demanding than in the UK. I see someone has mentioned GCSE's which are 15/16, aren't they? Or is it 14/15?
We had O Grades when I were a lad *mumble mumble mumble *
Ken bought 24 sweets, since he gave half to Jim and he had 12. Most of the question is just babble.
No, the ratio isn't just babble, you're assuming that by Jim eating 12 sweets, he ate all the sweets he had. The ratio part tells you this is not the case and that in fact they both still have sweets and chocolate left in those ratios.
Here in Ingerland 11 to 12 year olds are in High School and classed as year 7 (could be 8) if that makes a difference.
And the answer is very easy.
Ahh.. I remember these type of questions...
That is indeed a typical PSLE (Primary School Leavers Education) question. I was stumped when I came over here when I was 15, to find the UK's GCSE maths question to be those that I was doing in Secondary 1, 2 and 3 (13/14/15) A maths level (We had 2 type of maths, E Maths (Elementary and A maths, advance). In Singapore, Maths and Science levels are among the highest in the world though. We're still on the 'O' Level before 'A' Levels.
AS maths did caught up and then A level maths was round about the same standard (assuming it's based on Pure and Applied Maths). Further maths is on par with with A levels Advance Mathematics.
thing is it's probably a simple equation but since I've had no need for that particular equation since I sat my exams 22 years ago i've forgot what it was. :(
I'd be more surprised if I could get a higher score than a 12 year old at mathss. :o
