*** *** Sapphire ATI Radeon HD 5870 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card @ £399.99 inc VAT *** ***
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition. This card features Vapor Chamber Technology is based on the same principles as heatpipe technology. A liquid coolant is vaporised at a hot surface, the resulting vapor is condensed at a cold surface then the liquid is returned to the hot surface. The recirculation process is controlled by a wick system.
- Vapor-X Cooling Assembly
- Core Clock: 870MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Processing Cores: 1600
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Includes: Colin McRae DiRT 2 & Battleforge
- Warranty: 2 Years
Only £399.99 inc VAT.
ORDER NOW
probably not enough!
