dell dimension 2400
would a ZALMAN CNPS9500A-LED cpu cooler fir in a dell dimension 2400 case?
http://overclockers.co.uk/showproduct.php?prodid=HS-015-ZA&tool=3
One thing you need to double check is retention mechanism on the Dell same as what's the Zalman needs or if it can be removed and the Zalman one installed, being a Dell it's not always easy.
Ok, I was just wondering, how come when I play games with my Dell Dimension 4550, my fan gets louder? Thanks.
Your still using the cpu so the fans increase to keep it cool.
