Iv just secretly been attacked by the cable monster.
any advice on what to do to tidy my cables up?
heres a list of whats wrong.
CPU cable to short to reroute around the back
Motherboard power cable to short to reroute around the back
Card reader has a dodgy connection and it has to go straight it, cant make it come up at a tight angle under the mb
I have a IDE dvd drive. ( had it for 3 years )
My fan controller is fine, all the cables are routed at the back and cabled tied up at the top. thats all there is around the back.
Plan of actions:
1:Get longer cables to reroute around the back
2:get a SATA dvd drive,
3:Fitting my lianli hard drive cage when i get another HD to get more space down at the bottom
Any advice on cable management please say
also
Is there any 8 pin extensions for CPUS?
I have a 24pin extension for my motherboard. Just i found it hard to connect it up :\ it took a lot of force to get it in..but it wasnt right in, so i left it out.
Really any advice on cable management and keeping it neat would help a lot. If you could find me a link to buy a CPU extension cable that would be great!
typo on thread subject - Ment to be advice D:
Plan of actions:
also
