ASUS is one of the world's leading vendors of motherboards, the Taiwanese company is going all out with the releases of the P7P55 WS Supercomputer motherboard, Built on Intel's P55 platform, the new board has been specifically designed to accommodate the requirements of the workstation users.
Meet the ASUS P7P55 WS Supercomputer
Specifications
CPU
Intel Socket 1156 Core i7 Processor/Core i5 Processor
Xeon 3400 series server processor
Supports Intel Turbo Boost Technology
Chipset
Intel P55 Express Chipset
Nvidia NF200*1
4 x DIMM, Max. 16 GB, DDR3 2133(O.C.)*/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Support Intel Extreme Memory Profile (XMP)
Memory
Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Please refer to Memory QVL for details.
Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists)
Expansion Slots
2 x PCIe 2.0 x16 (@ x16 or x8)
2 x PCIe 2.0 x16 (@ x8)
1 x PCIe x16 (@ x4 )
1 x PCIe x1 (@ x1)
1 x PCI
Multi-GPU Support
Supports NVIDIA Geforce 3 way/2 way SLI technology
Supports ATI CrossFireX technology, up to Quad CrossFireX
Storage
6 xSATA 3.0 Gb/s ports
Intel Matrix Storage Support RAID 0,1,5,10
LAN
2 x Realtek 81112L Dual Gb LAN - Support teaming function
Audio
ALC1200-GR 8-Channel High Definition Audio CODEC
Multi-Streaming
Jack-Sensing
Front Panel Jack-Retasking
Coaxial / Optical S/PDIF out ports at back I/O
ASUS Noise-Filer
IEEE 1394
VIA VT6308S controller supports 2 x 1394a ports
USB
14 USB 2.0/1.1 ports
Diag. LED
Diag. LED checks key components (CPU, DRAM, VGA card, and HDD) in sequence during motherboard booting process. If an error is found, the LED next to the error device will continue lighting until the problem is solved.
This user-friendly design provides an intuitional way to locate the root problem within a second.
Overclocking Features
vCore: Adjustable CPU voltage at 0.00625V increment
vIMC: Adjustable IMC voltage at 0.00625V increment
vDRAM Bus: 81-step DRAM voltage control vPCH: 2-step chipset voltage control
vCPU_PLL: 4-step reference voltage control
SFS (Stepless Frequency Selection)
PCI Express frequency tuning from 100MHz up to 200MHz at 1MHz increment
Internal Base Clock tuning from 80MHz up to 500MHz at 1MHz increment
Overclocking Protection
ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x PS/2 Keyboard/Mouse Combo port
1 x S/PDIF Out (Coaxial + Optical)
1 x IEEE 1394a
2 x LAN(RJ45) port
8 x USB 2.0/1.1
8 -Channel Audio
Internal Connectors
24-pin EATX Power connector
8-pin EATX +12V Power connector
CPU fan with PWM control
Chassis fan1 with Q-fan control
Chassis fan2 with Q-fan control
Chassis fan3 with Q-fan control
PWR fan
CD audio in
1 x COM port connector
1 x USB connectors support additional 2 USB ports
2 x USB 2.0/1.1 ports
20-pin Panel connector
1 x IEEE 1394a port
TPM header
S/PDIF Out header
Front panel connector
1x MemOK! button
BIOS
16 Mb Flash ROM , AMI BIOS, Green, PnP, DMI v2.0, Wfm2.0, ACPI v2.0a, SMBIOS v 2.6
Accessories
1 x 2-port USB and 1-port 1394a module
ASUS Q-Shield
1 x ASUS SLI bridge connector
1 x ASUS 3 way SLI bridge board
User's manual
6 x SATA cable(s)
1 x com port cable
3 in 1 Q-connector
1 x Diagnosis Card(Retail version only)
Support Disc
Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.5 cm )
Front, inside and rear cover of the packaging that houses the ASUS P7P55 WS Supercomputer,
So what's in the Box?
ASUS Q-Shield
1 x ASUS 3 way SLI bridge board User's manual
6 x SATA cable(s)
1 x com port cable
3 in 1 Q-connector
1 x Diagnosis Card
Let's take a look at what ASUS P7P55 WS Supercomputer has to offer.
The P7P55 WS Supercomputer Motherboard is a work of art with a blue, white and black colour scheme, it uses an all solid-state 100% Japan-made high quality conductive polymer capacitors that incorporate various power saving features to increase its efficiency and improve electrical stability when overclocked.
Based on Intel's P55 Express chipset and combined with an NVIDIA NF200 chip, this new workstation motherboard from ASUS has been designed to provide users with support for the latest Core i5 and Core i7 processors, as well as the recently launched, Lynnfield-based Xeon 3400 series of processors.
The heatsinks are nicely placed on the 16+3 phase motherboard power supply with a thicker copper trace that has been used in the motherboard's PCB to help spread the heat more evenly this helps to decreases the overall temperature of the mosfet's and other ICs improving component life, there is a total of five fan headers on the PCB, one for the CPU.
The four holes around the CPU socket area are spaced differently to the socket 775 and socket 1366 mounting brackets so your old heat sink won't fit.
There are no power and reset buttons fixed on the P7P55 WS Supercomputer motherboard, but there is the G.P. Diagnosis card that assists users in system checking quickly and effortlessly providing precise system checks right after they switch on their PCs, only problem is though that when the lower PCI-E slots are in use then the panel will not fit so I think it is more intended for use in diagnostics rather than for daily use.
It has five PCI Express 2.0 x16 video card slots for multi-graphic card's that supports both ATI Quad-GPU CrossfireX and nVidia Quad-GPU SLI, by supporting either 3-way or 2-way multi-GPU solutions via both SLI and CrossFireX technology users can install up to three SLI-capable GeForce® graphics cards at x16, x8, and x8 connection speeds, or two graphics cards at true x16 connection speeds, alternatively, users can also use CrossFireX for a multi-GPU setup.
Users can also count on up to 4 CUDA cards (One of them should be Quadro graphic card) that are plugged into P7P55 WS Supercomputer for intensive parallel computing on tons of data, which can deliver nearly 4 teraflops of performance.
There are four dual channel DDR3-1600/1333/1066 memory slots which can accommodate up to 16GB of DDR3 RAM, Memory can be overclocked to run at DDR3-2133 speeds with compatible module's, The memory slots has retention clips on the DIMM slots at one end, Previously we have seen clip's at either end but now there is just one at the top of the motherboard with a small retention clip at the bottom which make things easier when removing memory modules when large graphics cards are installed.
The P7P55 WS Supercomputer motherboard has six 3.0Gb/s SATA connectors that can be paired up to make an Intel® Matrix Storage SATA RAID 0, 1.5 and 10 on these SATA connectors, the SATA ports are set at 90 degrees so as not to interfere with larger PCI-e cards.
There are a total of 14 USB 2.0/1.1 ports, 4 plus 2 raised of which are on the board next to the 1394a header plus 8 at the back panel.
The VIA VT6308S controller supports 2 x 1394a
Specifications
CPU
Chipset
Nvidia NF200*1
Memory
Expansion Slots
1 x PCIe x1 (@ x1)
1 x PCI
Multi-GPU Support
Storage
LAN
Audio
Multi-Streaming
Jack-Sensing
ASUS Noise-Filer
IEEE 1394
USB
Diag. LED
1 x IEEE 1394a
2 x LAN(RJ45) port
8 x USB 2.0/1.1
8 -Channel Audio
Internal Connectors
PWR fan
CD audio in
1 x IEEE 1394a port
TPM header
S/PDIF Out header
1x MemOK! button
BIOS
Accessories
ASUS Q-Shield
User's manual
6 x SATA cable(s)
1 x com port cable
3 in 1 Q-connector
Support Disc
Drivers
ASUS Update
ASUS Utilities
Form Factor
ATX Form Factor
ASUS Q-Shield
6 x SATA cable(s)
1 x com port cable
3 in 1 Q-connector
1 x Diagnosis Card
