I've threatened to do this so many times now I've lost count, and each time I get a load of advice then it all goes out of date. But anyway, I know where I'm going with the car so hopefully it's more relevant.
I'd like to overhaul the ICE in the car and I'm going to stick with the OEM head unit (As I'll be retrofitting the BMW 16:9 navigation and television in the new year).
This means I need 4 speakers and an amplifier. I'd favour a compact amplifier if possible as i intend to make the install as stealth and OEM looking as possible.
This is where it gets controversial. I'd like to include a set of 6x9's in the install.
Yes, yes, I know. 6x9's. The speaker of choice for the discerning chav in a Corsa. But there is good reason... I think.
I don't want to go to the hassle of having a sub in the boot because it's not particularly stealthy, the boot is a sealed enclosure anyway, etc.
The E39 has 6x9's as standard fitted under the parcel shelf so the theory is I can slip a set of aftermarket ones in there to provide me with some bass. Meanwhile, up front, I'll have a decent set of components fited in the original speaker positions in the doors.
So, I'm after:
1x Amp
1x Set of 5 1/2 components for the front
1x Set of 6x9's for the rear
Budget? Dunno, what do I need to spend? Lets say 300 quid for now. Can I get something that sounds pretty good for the money with this choice of setup?
Cheers guys.
So, I'm after:
1x Amp
Cheers guys.
