- 27 Feb 2007
- Leeds
Sorry long day, talking about ICHxR limitations not SATA2
Sorry long day, talking about ICHxR limitations not SATA2![]()
Is this better than the 64Gb version with 80Mb read/write speeds? I had a 64Gb drive and tbh i found it stuttered a bit.
There is an interesting feature of the Intel X25-M disk. If with a unused disk (or use HDDErase 3.3 to secure erase the disk), you create a partition smaller than the space available, the firmware will use the unpartitioned space in its wear levelling, which increases the expected lifespan of the disk. The sweet spot is a partition around the 62GB mark which gives a threefold increase in endurance ( http://intelstudios.edgesuite.net/idf/2009/sf/aep/IDF_2009_MEMS003/f.htm ).
So a 80GB X25-M partitioned to only use 60GB would give
50% capacity over the Kingston
100% increase in write speeds over the Kingston
200% increase in expected lifespan over the Kingston
and cost around about twice the price of the Kingston.
(which isn't to say you shouldn't get the Kingston, but should feature in your considerations)
Matthew
P.S. as the Kingston uses Intel firmware, it may be the case that you can achieve a similar result partitioning the Kingston to say 30GB. However, it is also possible this feature is disabled in the Kingston's firmware - I've not seen any information either way.
I disagree the Kingston is a good drive on writes. Just not the best. It is still better than most of the Indilinx and Samsung based drives.
