DIY Thread: How to make a Desk
Caporegime
25 Jul 2003
FR+UK
I bought the pine from Ridgeons, for a total of £38.95. The brackets and screws from B&Q for £8. I used my mitre saw to cut the wood into the legs, and my jigsaw to cut the panel to size.
Treating the wood is important naturally, as the pine is easily marked and will damage/scratch easily.
Drill the holes in the top/legs being careful not to drill to deep! I'd suggest drilling by hand unless you have a variable speed electric drill (which I used) as you might go to fast and end up going through the surface.
Brackets on both sides for stability, and legs indented to leave room for cladding.
And here is the almost finished product:
I'm going to go and get some more wood to add cladding around the legs so that the sides are covered, and about two thirds of the back - this will add stability and allow me to hide cables and what not away ;).
I'm going to be honest with you, its hardly the desk build of the year.
You should have attached the legs with propper fittings, rounded off the edge of the desk top, and built in something to tie the legs together.
:eek: Bit harsh, I'm no carpenter!
I know, it's pretty naff to be fair, the edges are rounded with the sander, didn't really feel like routing it though, I'd already used enough power tools for one desk :p.
No such thing as too many powertools. I have 3 drills :D
Looks grand, cheap, cheerful and does the job, though I do agree that you will probably need more support than those brackets for the legs (all depending on how much abuse you give it)
Did something similar myself this year due to my inability to find a suitable desk
The result:
Had to go with MDF due to cost (I was trying to keep it under €100), this has resulted in a few rough edges and I certainly would have preferred real wood but I'm happy enough with the results.
/hijack :p
Sorry, one thing i would do without fail it brace the legs, if you don't over time your desk is going to have a nice slant on it :p
I'm going to go and get some more wood to add cladding around the legs so that the sides are covered, and about two thirds of the back - this will add stability and allow me to hide cables and what not away .
So the op kinda is . . . . :p
And now I must stop posting. Must eat :D
no offence, but for the amount you spent you could have bought one from Ikea :D
The result:
/hijack :p
I had to do as you, use MDF, to keep my costs down when I did my desk a few years ago. When I made the desk it was much bigger, but due to moving I had to resize the desk to make it fit! :eek: The shelvings above my screens has been added on recently, due to need some storage space and somewhere to place my TV. Sorry for the mess, but not in the mood to do a clean up! :o
Sorry for the crap quality of the pictures, had to use paint to resize the pictures and resave them as a GIF to make the file size smaller then the 1.7 MB that they were at from the beginning! Don't have a better program then paint to use either. :(
lol i got rid of vhs years ago.
Well, I would too but I have programs I taped years ago and not find a good way to get them transferred to disc's without breaking my wallet, although haven't been looking lately so if you got any suggestions, feel free to let me know! :p
Get GIMP. Free.
Thank you! Just downloaded it, shall gibe it a try! :)
