Which card for COD6 MW2?
7 Jul 2008
Newcastle upon Tyne
Have £100 burning a hole in your pocked and need a new card?
Which one?
Edited:
Current spec quad core 2.4 Intel CPU
4 gig Ram
24" Dell Ultra Monitor
What exactly did the above poster say? I'd look but OCUK doesn't seem to work very well with Opera. Anyway, i'd have said a 250, 4850/70 or similar. That or an 8800GTX - they can be had for silly prices used.
I'm using opera and it works fine? You still using opera 9? Upgrade, all the bugs are fixed.
It was a 5770 to answer you though.
No, i'm on the latest version of 10. It's in Linux though... it sometimes works, but other times (like when clicking on links) it just doesn't load at all - or if it does it doesn't load the CSS properly, all i see is the left menu in the middle then it stops.
But yeah, a 5770 would be good if you could stretch a bit. Depends on the PSU.
A jeep would be pretty good :D
I can't see your £100 quid burning a hole in my pocket though :(
Agree with the above 5770, if you can stretch to an extra £20.
I can get one locally for £130 so only a couple of quid more than OC delivered.
Is the PSU going to be ok? Just running 2 ata drives and a DVD Rom
Don't read into that. Power supply quality (and thus amperage on the rails) is more important than the blanket wattage figure quoted by AMD.
Yeh I know quality has a lot to do with it, but the OP has a 375W Dell. Which wont be up to the task. Just pulled up the ATI specs page to get some quick numbers.
