My Rampage 2 has the top 2 pci-e 16x slots very close together, so my top 5870 runs 10 degrees hotter than the bottom 5870. Although I use MSI Afterburner to prevent overheating/throttling and its working out so far. This slot spacing while annoying is done to allow a 3rd gpu to fit in the bottom pci-16x slot to allow tri sli or crossfire, which is a bit pointless as you need a case with 8 pci slots since the last pci-e slot is on the edge of the motherboard.
Anyway I have noticed that the p6t has extra spacing between the top 2 16x slots, so this should definitely run sli/crossfire cooler. Although the 2nd card blocks the 3rd pci-e 16x slot on the p6t. However seeing as I will probably only ever runs 2 gpu's (maybe Fermi or 5970's in future when I get a bigger/more screens), and the fact I'd need a new case anyway, this shouldn't matter. Plus the P6T allows full length sound cards fit in the top pce-1 slot, unlike the Rampage which is limited to the SupremeFX unless you bend the heatsink pins back.
Anyway, long story short - is it worth selling my rampage and looking at a p6t deluxe ? Any disadvantages to the p6t compared to the rampage ?
