Hey Peeps,
I will be soon be stepping up a gear with my Microsoft Qualifications. Armed with a Dream Spark subscription (and possibly Technet soon) I am going to get as close as I can to a self contained production environment. This will be an ESXi based server, running as many VMs as is practical. The budget is £100 (no more please).
So far I managed to spec up a Dell PowerEdge T300 to a reasonable spec. But I cant help thinking that I would get more out of a whitebox, like an SSD or a SAS card (or both! The disk system is going to be thrashed!). Whilst I'm not going to need all the VMs to run Crysis, I would want a reasonable speed with several VMS to run concurrently, (Sever 2k3 & 2k8) a DC (or two) File-server, WSUS server etc. Along with client VMs (XP, vista and 7). Raid isn't a must but I would much rather have redundancy as well as the speed benefits of having the data-store on a Raid (and why not with 500GB HDDs barely £40!).
The major drawback with a whitebox is ESXi compatibility, I don't want to be doing too much with fiddling with th e “oem.tgz” file too much. Although I don't mind doing a bit as I am Linux proficient (enough
The only stipulations for the server are as follows:
A) that it has a Quad core CPU, 2.5GHz or above would be nice,
B) as much ram as possible 12GB would be nice, but perhaps 8GB.
C) It has a decent storage system, i.e. doesn't get bogged down with 5-6+ VMs
D) its less that £1000. (possibly a tad more but only if its really worth it) E) it works easily enough with ESXi 4.0, perhaps a couple of mods but I'M no going to spend days compiling or anything.
So should I go for a whitebox or a Dell or possibly(read preferably) a HP?? How many VMs will I be able to run simultaneously? (at a speed high enough to use easily it via RDP/TS)
Will I really need more than 8GB of RAM? (probably!)
Is it all that much trouble to change around the OEM.TGZ file?
If I can get help form someone who has done this, and/or has greater experience with running ESXi in a production environment, or is just a pro at speccing a computer up for ESXi, it would be greatly appreciated, cookies are available.
Cheers V. much!
Cheers V. much!
